Misha
August 2, 2015, 10:58pm
1
Wan't to make my PC Black/Red and since my Motherboard, Sound Card, PSU,GPU, Fan's & Case are Black and Red I wan't the cooler to fit in because of the side window.
Red/Black Heatsink. (Can be both or one of both.) Fan 120MM with Red LED's. RPM Max 2000-2500. Socket 1150. MAX Height (Overall) 155mm.
The cryorig h7: cheap, performs great, and really small. Comes with black and white fan but you can replace it or paint the fan blades.
The cryorig H7'd probably do, if you really want you could switch out the fan for something that's not got white blades.
EDIT: lol I see @W1tness got there before me.
ayyyyyy lmao. JK I personally have the ets t40 but the H7 is essentially a good looking Hyper 212 killer.
Don't forget about Phanteks 120mm and 140mm coolers. They are very nice!
Zibob
August 3, 2015, 1:45am
6
Will this do?
Prolimatech Red Megahalems CPU Cooler
Comes in at 158mm tall? maybe a squeeze?
You need some fans for it though, that takes 120 or 140.
Prolimatech Red Vortex Red Wings Red LED 140mm Fan
Or these:
Aerocool DS Edition Fan - Red - 140mm
Or these:
Alpenföhn 140mm Wing Boost 2 Plus PWM Fan - Red
Or maybe some see through ones?
BitFenix Spectre PRO 140mm Red LED - Black
Misha
August 3, 2015, 11:25am
7
In one description of it, it said it accepts only 120mm fans. And would a ,,Corsair Air Series SP120" fit on it?
I have the deep cool captain 240, really love it. If you're looking for a heatsink cooler, then the Hyper 212 Evo with Thermaltake "Riing" fans.
My cooler:
Riing fans:
the megahalems in red almost doesn't exist anymore. Or at least not where I've looked. The Black version is really nice too but imo a bit pricey for performance.
Zibob
August 3, 2015, 2:22pm
10
Ah yes I see. Only the Revision C of it.mentions 140mm fans, the other only say 120. Sorry about that.
@W1tness there are 10+ available where I got my parts. https://www.overclockers.co.uk/showproduct.php?prodid=HS-027-PL&groupid=701&catid=2330
