Hello,
I bricked a Supermicro H11SSL-NC Rev. 1.01 mainboard by flashing it with the BIOS version 3.4. which is only meant for Rev. 2.00 boards. I overlooked that because the system already was on 3.3. which is supposedly also not for that board. But that is what it had and the IPMI still things it has:
sum.exe -i 10.0.0.204 -u ADMIN -p "Pass" -c GetBiosInfo --showall
Supermicro Update Manager (for UEFI BIOS) 2.15.0 (2025/11/04) (x86_64)
Copyright(C) 2013-2025 Super Micro Computer, Inc. All rights reserved.
Managed system..........................10.0.0.204
Board ID............................1A03
BIOS build date.....................2025/05/27
BIOS version........................3.3
SMBIOS:
BIOS revision.......................5.13
FW global version: 0
CPU signature: 00 00 80 11
Description: ZP B1
Version: 08001129
CPU signature: 00 00 80 12
Description: ZP B2
Version: 08001278
Device type: Generic LAN
Device ID: 5223
Vendor ID: 32902
Device description: Intel iSCSI
Version 2.7.128 support: LEGACY|PXE
Version N/A support: UEFI
Device ID: 5223
Vendor ID: 32902
Device description: Intel Giga
Version 1.4.04 support: LEGACY|PXE
Version 6.1.16 support: UEFI
Device type: VGA
Device ID: 4874
Vendor ID: 8192
Device description: Aspeed Graphic
Version 1.09.00 support: LEGACY|UEFI
AGESAPI version: 1.0.0.Q
BIOS build date: 2025/05/27
BIOS version: 3.3
UUID: 2B2D8B64-A63A-F011-BB62-0CC47AFBDDC9
BIOS unique name: BIOS_H11SSL-1A03_20250527_3.3_STDsp.bin
Now I have the problem that I can’t flash a different version.
IPMI > Maintenance > BIOS Update
gives me “BIOS image size doesn’t match flash size.” for 32MB images (officially unsupported for Rev1.01, I know)
and “BIOS can’t pass the secure validation.” for 16MB images.
sum.exe -i … -c UpdateBios --force_update --file BIOS_H11SSL-1A03_20250527_3.3_STDsp.bin
gives me
Status: Get wrong status code. 12 (BIOS length mismatch.)
Done
********************************<<<<<ERROR>>>>>*********************************
ExitCode = 148
Description = IPMI execution exception occurred
Program Error Code = 427.7
Error message:
UpdateBios failed, status check reached max retries.
for 32MB images and
sum.exe -i … -c UpdateBios --force_update --file H11SSL9.625
Status: Get wrong status code. 16 (Update package verification failed!)
Done
ExitCode = 148
Error message:
for 16MB images.
I did a CMOS reset and leave the CMOS battery out overnight. I opened a ticket at Supermicro and got a BIOS file but they have stopped responding. I also tried every H11SSL BIOS from https://drunkencat.net/misc/SupermicroBIOS.html
I did the update to from 3.3 to 3.4 via USB stick. From a different update I still had a Lenovo BIOS update on the stick with a startup.nsh file. Upon booting into UEFI it triggered the startup.nsh meant for Lenovo which started the AMI Firmware Update Uility. It stopped after reading flash since the checksum was wrong. After that I flashed with flash.nsh BIOS_H11SLL…bin like you are supposted to do. I don’t think the Lenovo thing damanged something but I want to mention it for completness.
Is there still a change rescue this via IPMI/sum.exe or do I need to buy a USB flash programmer?
