I will be buying a new CPU and MOBO. Probably in the future might try and get a 2080 card. I would like to try AMD CPU. What recommendations do you guys have?
The only task where throughput of the hardware is a condition is in gaming. No video editing .
I would like something all together with RAM + CPU + MOBO around $500 or below.
I almost forgot, I will be doing this on a 4k monitor.
If you want the best gaming performance out of that upcomming GTX2080.
Then intel would still be a better choice basically, depending on the resolution you gonna game on.
because they clock higher and in most games perform better.
The 9th generation of cpu´s well be released soon.
But the current 8th gen cpu´s are also a pretty good choice.
Something like the i5-8600K with a Z370 board.
But if it has to be AMD, then with a budget of arround $500,-
You could go with something like a Ryzen 5-2600X and a Asus X470 Strix motherboard.
That would be a decent combo.
That gets you right to $500 on that if those are options and you really want to be strict with the $500. Otherwise, you can adjust the board and memory options for $50-80 more and get stuff anywhere, but just check pcparts picker I’d say to work it out as you need/like.
Would it be a bottleneck to not go for Intel? What is the severity and price difference for going different routes? I obviously dont want to buy something that cant take full advantage of the graphics card.
Well wenn gaming in 4K you will probably be gpu bound in most games and gaming scenario’s,
especially wenn you turn up all settings to the max.
So in that case i expect that the overall performance differences will be minimal in most games.
But if you game on 1080p or 1440P, then the differences in overall gaming performance,
are more significant in raw fps numbers.
Because of the clockspeed and per core performance advantage that intel cpu’s still have.
And therefor generally perform better in 1080p / 1440p gaming with the highend gpu’s.
Take a look at Jays last video on AMD performance with 2080 and 2080Ti. He does a comparison between 2700x and 8700k. Both are more or less equal in synthetic benchmarks and the few “newer” games he tested them on.
System is a Crosshair Hero 7 WIFI, 2700X and 16 GB. I didn’t check prices though.
Yeah well like i mentioned above on 4K you will be gpu bound for the most part.
So in that case the performance difference would be really minimal maybe marginal at best.
The differences will mainly start showing at lower resolutions like 1080p and 1440p.
At those resolutions the Ryzen cpu’s will hold back the card somewhat.
The only thing with Ryzen archtitecture is that it doesnt really overclock that well.
And its very ram speed and timing’s depending by design.
So thats definitely something to keep in mind, that you pick a decent set of ddr4 modules.
Something like G.skill Trident Z 3200mhz cl14 / cl16 samsung B-die is recommended.
not on 4k if you only use one 2080Ti, cause the GPU is simply not able to keep up producing enough frames for a bottleneck event to happen. if you want to find out about if a ryzen or intel system bottlenecks on that 4k level, simply buy a second GPU and run them in SLI, or whatever it is called now.
I wouldn’t go for an SLI, most games won’t work well even if you get over 60fps 4k (mainly because of a micro-stutter which leads to lack of smoothness and bad frame times).
I don’t think you should worry about this too much. Because in most games where there are “significant” differences. The differences subjectively don’t matter, because once they occur you’re mostly well past 100fps anyways and then when you crank up the resolution your fps get more and more the same.
With Intel in that price range you are also likely looking at a 9600k. Where when games take advantage of more than 6 threads AMD might very well at least close the gap more often than not.
Another good option would be to look for a used 8700k from those people who bought “the worlds best gaming CPU”.
Also being able to pop in the newer AMD 7nm stuff into AM4 once it arrives and some after that one is nice. One thing that AMD has going for them. Wether or not you care about that is another story.
