My motherboard only supports Ethernet and I was thinking of getting a PCI Wifi card because the link speeds are bad. Our university wifi infrastructure is new and robust, but the Ethernet connections are still on phone jacks.
I will probably use this for gaming in windows seeing as my download speed in Linux is not really a priority
I was thinking of getting this
If you plan on using Linux that ASUS card isn’t the best option. It is a Broadcom which commonly have issues on Linux. For Linux Intel WiFi cards are pretty much what you want and they’ll work great.
I can confirm that this WiFi Adapter works well under both Windows and Linux:
