for silence i would say try to get something from Noctua or Bequiet!
Since i don't know many stores in the UK, i can't really judge the pricing. maybe this is outside your budget. But this could be an option that would keep it relatively cool and most definitely silent:
The H80 liquid cooler isn't the quietest cooler out there man. If you want a cooler based on silence, go with Noctua, BeQuiet or a simple cheap Arctic Cooling.
The Dark Knight performs better than the 212 EVO. I think the H80 would probably be the better bet, as water coolers are usually quieter and cool better than the lower to mid-end air coolers on the market, but you should look for reviews online to see what you want. Also if your case has a window, a water cooler may be the better choice as it allows you to look inside the case and see all your sexy components. In the future you could change some of the fans to Noctua ones and get cooler and quieter performance too!
