Hey all,
In the next few months, I'm going to be building a dual-socket E5-2670 build, but I have no idea what to do as far as the motherboard goes. I'm familiar with desktop equipment, but when we step into workstation/server grade stuff, I'm lost. From what I understand, these CPU's need the C602 chipset. Not sure if you can dual-socket X99.
Ideally I'd like to have the following:
- 6ish sata ports (2, 3 doesn't matter, my NVMe will be on pcie)
- at least 2 pcie x16 spread so that I can put air-cooled GPU's in them.
- either dual-gigabit or single 10gig onboard. no broadcom if possible.
- USB ports. type-c can be added via PCIE, but I need at least 4 USB 2.0. USB3.0 is preferred obviously.
I don't really know what to expect as far as price goes. I've done a little cursory searching for the C602 chipset and realized that I was out of my depth. With that in mind, I'm expecting it to cost around $600 for the motherboard, but if I don't have to spend that much, I'd be happy. If it goes over, I'm fine with that too, I'll just push the build back. This isn't a time sensitive build. I've already got the 2670's sitting on my desk, but that's mostly just to lock in the price that I got them for. $65/ea
They're beautiful, by the way.
Everything else is sorted out, I'm going to be using mostly spare (or pulled from active duty) parts lying around:
- 4x WD Red 3tb
- 2x NVMe intel 480GB ssd
- 1x EVGA Supernova 1000 G1
- 1x R9 380
- 1x GTX 660 ti (possibly upgrading to a RX 480 if the performance is right)
- 4x 8GB DDR3 1866MHz
Haven't decided on a case yet. I've got an 800D that I can use, but if I need to buy another one to fit the motherboard, I'm fine with that.
