If you’re at 4k drop AA completely, that should bump up the fps, you’ll want to do that on a 3080 because that probably won’t be able to run it either at 4k120
I mean settings wise I would say just stick with whatever the “High” profile suggests. In general anything above that is barely visible but hammers fps, especially in 4k. After that you can manually disable things you don’t want, AA, motion blur… whatever.
Good, there should be something good on the market by September/October.
RTX 2080 Ti - 9900K, Minimum.
