My budget is 1,000$ atm, and I've got 50$ on my case but I'd be willing to invest max 30$ more as long as that would buy me one that would last through several builds. Right now, I've got the Rosewill Challenger, which seems like a pretty good case, but it lacks any front external USB 3 ports, which I think should definitely be available at this price range. Also, I'd like it if I could get some fans with the case so I don't have to worry about getting as many, if possible. I don't want anything super flashy or plastic (I need to be able to move this around without worrying), and right now black is my safest color option, although I wouldn't mind a blue accent. Also, a window isn't necessary. I guess that's a lot of criteria, but there's gotta be some stuff out there, right?
I put the 300R last simply because I am not into the fake rivets on the front. Also, the 200R has a plastic hard drive cage and if you put more than two hard drives close together, it will trap heat, leading to overheating.
Also, there is no cutout for the 8 pin cable on the Core 3000. You can route it between the motherboard and the motherboard tray through the motherboard cutout.
The Core 3000 is really great for the money. I personally have the HAF912 Advance. I don't see it on the PCPP list of cases. Good case and excellent temps.
