Recommend me a pillow
Recommend me a good pillow.
Vanity or throw pillows need not apply.
Orthopedic pillows are also considered.
What's yer budget?
Does this work for you?
Here is a good starting point for the above suggested
Waifu Pillows. can't go wrong lmao
*Body pillows
And you usually just get the covers, you buy the actual pillow seperately.
Memory Foam Pillow's
HERE
Don't click his link. It's a referral link. I corrected it below. Not interested in a body pillow. But I have to admit it is interesting to find the spammers in one thread. Congrats you've just made a very special list. This is the second time tonight you've done sh&t like that to my topics. Go back to 4chan now.
Still looking for a pillow though that isn't vanity or a throw pillow, and doesn't include sexual connotations from the sickos listed above.
Have you tried it? Going on no sleep for a few days now so I really am in need of a good one.
I have 4 of them i am a insomniac and thay realy help me relax.
Any back, neck, or head aches or anything like that? Is this the exact model you have? The reason I ask is because after sleeping on the scrap I have I feel like I've been hit by a truck
well buying a pillow that fits your comfort perfectly is realy a personal thing.
I use Auping pillow's, which in my opinnion are realy good.
Not sure if you can get them where you life?
Otherwise you might check those out.
I think the best way to find a pillow that gives you the best comfort,
is going to a shop, and ask advice.
Well I was taking a look at this for the last couple days: http://www.consumersearch.com/pillows
Bit pricey though.
I am typically on the move all the time so buying online is usually the best bet for me, and since a store and the people there know absolutely nothing about things like this off-hand it's always best to ask people that I trust (well today proved otherwise...and I am a bit groggy...so today is temperamental/cranky for me)
I used to kickbox in my early years i broke my back and have painfull arthritis in most of my joints along with a couple of broken ribs, these are the ones i use you sink in to them and thay keep you in place so you dont move around in your sleep.
Its like sleeping on a giant marshmallow just turn them around every night.
This is the type of info I need. If I went to a store they would just try and push some nonsense on me. I appreciate the honesty. I think I am going to buy them if all I have to do is flip them like a steak
Yeah some particular brand pillows are a bit expensive.
But in my opinnion, somethimes they are realy worth it.
Still its realy personal.
Not too sure what you mean by referring to about the second time. This is the first time I have ever commented on one of your threads.
I am quite serious about the large pillow. They are quite comfortable and this is one that won't break the bank.
Well I am glad you found something you were looking for.
Tek Pillow?
Pillow Syndicate?
Tek Pillosyndicate?
Pillek Syndicaow?
I had just got out of a thread a few minutes before with misteryangel that was spammed to death (and locked) and she knows who I am referring to. I was tired and exhausted when I wrote up this thread and I'll leave it at that (still am to be honest).
