Recommend me a KVM that supports samsung odyssey G9/logitech G915/logitech G903
Keyboard and mouse needs to have all functionality working including macros and G Hub RGB
level1 kvm will work fine for this, but the kvm hotkeys for input switching might not work depending on how fancy the keyboard is.
the keyboard itself would work fine with the PC including macros and rgb though. Assuming it doesn’t need more than 950mah.
What about the monitor, will it be able to work at 5k resolution and 240Hz refresh rate?
the kvm is dp1.4. If the monitor adheres to dp1.4 spec, it’ll work. Don’t know enough about the display to know that for sure. If it doesn’t work you can return it, and you’d just be out shipping.
