Recommend Digitial to Analog sound converter?
Does anyone have a recommendation for a decent converter?
yup, the behringer UAC 202
Will that work for my tv and home theatre system? i.e. My home theatre only supports analog and my tv only has digital out for external speakers. That seems to be strictly for PC.
Does anyone know?
What do you mean digital out? Optical, hdmi or a jack?
Optical
So basically I need a digital optical to rca analog stereo converter. Anyone know of a decent $20 to $30 option? I see a lot of them on amazon but I would like some opinions from someone.
I'm sure I will find someone who knows
So youre basically looking for something with optical in, Rca out. hmm oke ill take a look
These are great: http://www.i-enjoy.com.au/ProductDetails.aspx?ID=91
http://www.jaycar.com.au/productView.asp?ID=AC1603&keywords=toslink&form=KEYWORD
kinda expensive tho.
I Do not have any personal experience with the Fio but i can tell you, its a very strong and good brand so if youre buying one of these two, go for the fio.
Hmmm...it looks like I will have to buy a new sound setup. All these converters I'm looking at apparently do not work with Dolby, 5.1 Surround, or DTS. It seems if you try to get any of those to work all you get is random noise. Oh well. Thanks for your help :)
