I have been noticing that theres records I want to buy that are popping up. Idk if I’m trash or not.
Recommend me a record player that isn’t a billion dollars. Needs a quarter inch audio out. Idk shit about them.
Technics.
Only Technics.
https://www.technics.com/global/introduction/hifi-direct-drive-turntable-system-sl-1200gae/
If you can’t get a new one, get a used one, and make sure it’s “direct drive”
I feel like I could part oun a sansui sound system and get basically the same thing.
Look through his videos. He reviews older sound system equipment and you could get a good idea of what to look out for when buying something.
Stanton ST150´s are also pretty good.
Audiotechnica AT-LP5 is pretty good.
They have these at barnes and noble locally I think.
