Recommeded Upgrades?
Going off of my last post I want to see if there are any upgrades that I should do?
This computer is mainly for gaming and watching movies. The only other thing it might do later is an Internet radio show.
CPU - Intel i5 3570K 3.4GHz LGA 1155
Motherboard - Asus P-8Z77-V LK Socket LGA 1155 Z77 ATX
Ram - Corsair Vengeance Series 8GB DDR3 - 1600 (PC3-12800) CL9 Dual Channel Desktop Memory Kit
Power Supply - Corsair CX Series CX750M Watt ATX Modular
Hard Drives - Corsair Force SeriesCssd-F1156B2 Sata 3.0GB/s 2.5" Internal Refurbised
                       4x 500GB Sata 3.5" Internal Hard Drive Refurbised
Case - Corsair Vengenance Series C70 ATX Mid Tower
Graphics Card - EVGA 02G-P4-3662-KR NVIDIA GeForce GTX 660Ti Superclocked Edition 2048MB GDDR5 PCI
His parts list states he already has a corsair ssd
Depending on your upgrade budget you could get a new GPU, something like an R9 280X or maybe even an R9 290 but anything less than those would probably be a sidegrade
Thank you I'll look into the new GPU, my buget is whatever I can save up for lol, that or wait until Sept when my birthday comes around.
Is there any cooling system you guys would recommed I have done a few stress test on my cpu and it gets into the Yellow (hot) really fast I'm running the standard fan on it. Should I just get a better CPU Fan or should I water cool?
If your not going to do any sort of massive overclocking a Cooler Master Hyper 212 EVO would be a pretty good upgrade, but if you want to do high overclocks then possibly consider a Corsair H100i or Noctua NH-D15
I dont know how to overclock and I dont plan on it until my second build
Go for a Hyper 212 EVO, it should be more than adequate and is fairly cheap
Thanks :D
