Hey Guys,
I am looking for CPU cooler that can fit in my "Mini Tower" on my GA-78LMT-USB3 motherboard. Idle my CPU is running at 41 °C which I don't think is horrible but I still like to keep my case a little cooler. I keep my PC in a cold room in the basement so cooling is not really and issue but hate that I am using the stock CPU cooler.
Regards
Adrian A. Pinnock
CPU: AMD Phenom II X6 1040T
how high can the cooler be in your case?
http://www.amazon.com/Cooler-Master-GeminII-M4-RR-GMM4-16PK-R2/dp/B0080ATR2Y/ref=sr_1_1?ie=UTF8&qid=1391454899&sr=8-1&keywords=cooler+master+m4
make sure it will clear your ram. Other wise measure how high the cooler can be and go with something like this. There are more expensive options but these will do the job.
http://www.amazon.com/Cooler-Master-Hyper-TX3-RR-910-HTX3-G1/dp/B0028Y4S9K/ref=sr_1_1?ie=UTF8&qid=1391454996&sr=8-1&keywords=cooler+master+tx
bro, you recommended a heatsink, he asking you you to re-command that shit. command that heatsink to work!
From the motherboard to the case wall it's about 7" I don't know if that's enough room or not for anything decent. Is there away I can get notifications on a forum post? Currently looking at your link "ragingh4vok".
I measured the space between my CPU and the RAM the cooler might just clear it but I would be willing to spend more money for something that fits a better. Money isn't to much of an issue but I don't want to drop to much money on a piece I only use for a bit of gaming and 3D modelling.
