Has anyone else encountered issues like these I’m trying to use discord on the latest version of Manjaro and my Blue Snowball microphone just sounds like this. https://instaud.io/3zvI . I’m pulling my hair out trying to fix this issue but nothing seems to work.
This is the sound card i’m using alsa.name = “ALC887-VD Analog” device.product.name = “SBx00 Azalia (Intel HDA) (M5A78L LE)”
I hope you guys might have to insight on this cause I’ve run out of ideas, thanks.
I do not use discord but heard other Linux users say must turn off echo-cancellation and automatic level control, no different to other VOIP packages I use
is it plugged into a USB 3 port? I’ve had issues using usb microphones/headphones with USB 3. If you have a USB 2 port available try plugging it into that and testing again.
