Hey guys, I am currently wanting to re-build my pc (its a crappy packard bell but im planning to essentially build a new one), I already have a graphics card (radeon 7850) and a dvd/cd drive and hard drive etc etc. but I need to upgrade my motherboard which uses DDR2 ram and is generally crap.
This is the parts list that I came up with: http://www.ebuyer.com/lists/list/36091
My budget max is £210 so I would really appreciate if you guys could make improvements to this. If you guys could find a better case that would be awesome, If you find another motherboard then please make sure it supports 32GB of ram and 2 pci express x16 slots.
If you could find a better intel option that would be awesome, but AMD is crazy cheap so I instantly went down that road.
i would get a dual channel kit of memory to start off with, using one dimm in a board that uses dual channel mem will cause a performance hit, and with the 32gb of ram idea i think it would be better for u to stop at 16 gb, not many programs are gonna make use of that much unless u do 3d modeling and the such. video editing is usually fine working with 16gb. however if u do want to use 32gb and u r gonna use windows 7 make sure u get the windows 7 pro 64 bit edition
Thanks for the memory advice, I am already have windows 7 ultimate 64 bit :) but i will also be dual booting with ubuntu 12.04 64bit and the ubuntu machine will really be my main OS after a few years hopefully (please valve!)
Edit:
I have updated the list with better dual channel 1866Mhz memory.
Also, no reason anymore to get Piledriver. Get the new Vishera CPUs, they're faster, more power efficient, and more overclockability. Get the AMD FX-6300 , or at least an AMD FX-4300. The 6300, for only $10 more, is a better deal.
I know that case is great and all, but it's a bit small IMO. It can't fit a 7970 ( particularly an ASUS or Gigabyte one). So you'll be a bit limited in future upgradability options. If you want more options, a Cooler Master HAF 912 will fit a long card if you remove the modular drive bay. Or a Corsair 300R or 200R will fit them off the bat. More expensive though.
Here is my improved list: http://www.ebuyer.com/lists/list/101901 I have a really tight budget guys so I decided not to upgrade the motherboard or the cpu but i did upgrade the case and the RAM. Any more improvements on this would be greatly appreciated.
