I want to build a Mini-itx gaming machine that'll be liquid cooled down the road, but I have already have parts my current build.
I already have a Radeon 7770, a Corsair CX500 watt PSU and 8 Gb of Corsair Vengeance 1600MHz..
I will spend about $400 for a new case (I want a bitfenix prodigy)
I want an Intel CPU hopefully an i5 (I don't want Haswell{ I hear they get really hot})
And I have an extra 2TB hdd laying around, and a copy of windows 8.
Thanks in advance! :D
If you're planning to wc then grab a haswell 4670k - h100i fits in a prodigy easy enough. There is no point in going back to ivy/sandy unless you score a stellar deal.
http://pcpartpicker.com/user/deejeta/saved/3msH - rough idea.
Ideally a custom loop is king in the prodigy but I dont know what your plans are. >https://www.youtube.com/watch?v=Ls364OqUNb4< is what can be accomplished in that case.
Yes, I want to get a custom loop, (i just dont like my H60, it doesnt preform aswell as i need) a but thankyou!
One other question, are there AM3+ mini itx motherboards? If their are I can upgrade to one and used my money on something else than another processor (probably an AMD R9 280x)
nope. either FM2 or intel.
what are you thanking us for?
