Hi, new to real server hardware and looking for advice on cost efficient RDIMM selection to not leave too much performance on the table. CPU is the AMD EPYC 8224P. Running proxmox as homelab, so nothing mission critical.
Does anyone know if the Threadripper designed DDR5 with 6400 MT/s work on Sienna at that speed?
Otherwise it seems 5600 MT/s would work from Micron
Has anyone seen relevant benchmark if it is worth the increased energy use and performance (mixed homelab activity), to have same GB split into more DIMMS?
Per below from manual, it seems 6 DIMMs is the sweet spot while retaining the higher MT/s on the ME03-CE0?
Or is the gain going to 12 DIMM bandwidth (mixed use homelab, no video editing) at 3600 MT/s worth the expense and energy use increase?
You might be able to get 5200MHz on sienna if you have a very light RAM load on the CPU (only 6 DIMMs, single rank or maybe even double rank), that is assuming the BIOS even lets you overclock the RAM which isn’t a given on these server boards.
You will have less overall memory bandwidth if you go from 6>12 DIMMs on the sienna platform. The IO die that AMD uses has a hard time driving more memory and slows down.
EPYC 8004 has 6 memory channels. So everything above that is 2DPC (two DIMMs per channel). This comes with obvious capacity benefits, but reduce the clock speeds. I think AMD specs for full 2DPC and 2R modules is 3600MT/s on Zen4.
But if you need more channels without compromises on clocks (retaining the 4800MT/s), get 9004 EPYC. But even there, 2DPC behavior is the same, it just starts after 12 DIMMs instead of 6.
I wouldn’t recommend Siena if you need more than 384GB of memory(64GB DIMMS). Get the platform where 1DPC fits your needs and 2DPC is just the desperate choice for more capacity .
I got a 8024P and the Gigabyte ME03-CE1 motherboard as well as 6 Micron 16Gb DDR5 ECC RAM sticks (MTC10F1084S1RC48BR). The 4800MT/s speeds are only guaranteed at 1DpC, you’ll get less with 2DpC (I believe at some point it’s 4000MT/s and 3600MT/s - in my case at least).
I remember, that Micron memory sticks are a little bit better than the Hynix ones, but I forgot why.
