Has anyone tried rclone backups to the relatively new Linode object storage (s3 compatible)? I’m looking for an offsite backup location for my home desktop files (about 100 GB). My only concern is the sheer number of files needed to be diffed and checked. If I have a million files on my local desktop, is that even feasible if it needs to hit a REST API for each one? I would also be encrypting them via rclone. Thanks.
I don’t really have a great answer for your exact question, but how about using restic instead of rclone? It has encryption built in, and packs files locally into chunks for upload and has a native s3 backend.
Rclone has an option to process multiple files at once. On a home connection I can usually saturate my vdsl at 20, so I see no issue pushing through lots of files. (Though this is to b2, but similar enough).
Just make sure you read all of the documentation - Amazon S3 - particularly the section “Reducing Costs”.
Another option is to use a backup system like borg backup, and use rclone to replicate that to the cloud. This gives you encryption at rest, point in time backups, and will chunk lots of small files into a single object.
