I was hoping Razer users could / would lend a hand with how to use a Razer mouse. I was gifted a Basilisk v3 because “Linux has Razer support.” So far this seems like a half truth if not a lie but hopefully someone can refute this.
I installed OpenRazer which is a mess in itself. I then tried Polychromatic, RazerGenie, Snake, input-remapper and Piper…not a single one does F all other than lights and DPI…
So how the hell do you map buttons?! I am looking into xremap and keyd but so far the docs are clear as mud, as was the xev output about what the buttons defaults are. LE HELP!?
I think I am figuring out input-mapper…maybe…
welp never mind, sending this POS back. You can’t even map the buttons correctly in Windows with the actual Razer bloatware.
