Hi!
I am wondering if this panel I found is compatible with my Razer Blade 15 base model.
The original razerblade panel: NV156FHM-N61
The panel I want to upgrade to: NV156FHM-NY1
Hi!
At least according to panelook, the dimensions, voltage and connector are the same. So theoretically it should be possible.
http://www.panelook.com/NV156FHM-N61_BOE_15.6_LCM_overview_29824.html
http://www.panelook.com/NV156FHM-NY1_BOE_15.6_LCM_overview_41243.html
The one you want to upgrade to is 144hz, and although not the same panel, this guy did have a problem with 144hz on a BOE panel: (he has the advanced model laptop tho)
Thank you so much for replying. I have struggked to find any informations about this anywhere.
The only thing I noticed was that the 30 pin connectors on the screenside looked a bit different the NV156FHM-N61 panel. It looks thinner.
The panel on the Blade 15 Advanced is a different one though. But yeah, the panel is 100$ on aliexpress, so I think I will take a shot.
Did you buy the panel NV156FHM-NY1? Is it good? I am planning to buy one on aliexpress.
This is closed as it is outside the revived thread guidelines. Feel free to create a fresh topic, or PM me or one of the Leaders if you think this was incorrectly closed. See here for more info.
