Motherboard: Asus M5A78L-M/USB3
Cpu Cooler:Zalman CNPS 9700 Led
GPU:EVGA GTX 760
If your asking why I want the Gtx card it is because I got a Nvidia Shield.
Change that board out with this one, http://www.newegg.com/Product/Product.aspx?Item=N82E16813128627, and then find a case that you like that will fit it :P
I have looked at that board but as an active Lan gamer I really like the m-atx form factor and the handle on the NZXT Vulcan. Thanks
Why not go ITX then? :P
No cases that I like with the handle in ITX form
no pics
not real
no care.
um what?
should be, "RATE MY LIST OF PARTS"
Probably should sell it all and build a intel itx. Amd doesnt really have good matx boards.
i'll give it a 3, cause of the lowest denominator of a power supply.
can you recommend a better one?
I would rather stick with AMD, better price to performance for the CPU's
http://www.newegg.com/Product/Product.aspx?Item=N82E16817438012
That looks good, I'll look around at reviews and stuff for that, thanks for your help.
