EDIT: BIG UPDATE.
http://pcpartpicker.com/p/Cryf
self explanitory, just a thing, all parts were kept under $200 as i have to purchase them seperately anyway (#poor-person) so if any revisions are to be made, keep the parts under $200
only thing i need help finding is a 24bit 192khz 7.1 soundcard with regular 3.5mm jacks for headphones, mics, and PC speakers or w/e can be used without having to get loads of converters or an enxpensive amp or w/e (unless the one on the MB isn't shite, i'm a bit of an audiophile though)
i would cut back on the mobo and beef up your gpu.
http://www.ncix.com/products/?sku=78372&promoid=1292
otherwise looks good
GPU link is not working, brings me to the homepage, but as long as the GPU is under $200 STRICTLY, i can't spend more than that much at a time
(remember #poor-person)
sorry here its not much more
http://ncix.ca/products/?sku=78372&vpn=AX7870%202GBD5-2DHPPV3E&manufacture=PowerColor
i think $60 over is way too much, even $40 over (which is how much after rebate) besides a 7850 is faster than a 6950 in the majority of situations. http://www.anandtech.com/bench/Product/510?vs=549
Still Need This Information Guys, if you can please help:
i need a case (something with a sturdy handle and good airflow, i'll be going to lan parties every now and again, is there anything better than the CM scout 2? that's about all i can find to fit the bill)
And 120mm fans to replace all stock, i need to know what the absolute best performing 120mm case fan is. (IDC about noise as long as it isn't rediculous), and also what the absolute best performing "pressure" 120mm fan is, for my CPU heatsink. (agian IDC about noise as long as it isn't rediculous)
These fans are really good for static pressure, and you can either buy a single fan or get the twin pack which saves you some money if you want more than one:
Corsair SP120 Performance: http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&N=-1&isNodeId=1&Description=Corsair+sp120+performance&x=0&y=0
This is probably one of the best case fans I've ever seen before:
Xigmatek XAF-F1255: http://www.newegg.com/Product/Product.aspx?Item=N82E16835233101
As for the case, the Scout 2 is probably going to be your best bet.
When it comes to the sound card, I'm not too sure. The only card I know that does 192khz is the ASUS Xonar Essence STX, and it doesn't fit the rest of your specifications. You might want to check out what Auzentech has.
I must say don't get MSI. For the past years everytime I get a MSI mobo i end up returning them. MSI is good with Vid card and there Mobos are terrible.
Try the gigabyte 990FX. It's cheaper and more reliable.
