Rate My $650- Budget Build
Hey guys,
Just about to order my parts and before I do, I wanted to make sure I have a good build for the amout I wanted to spend, although I went a little over budget.
If you can, please checkout my build and rate it for me or tell me if i should replace anything.
http://pcpartpicker.com/parts/partlist/
RAM -- http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
(comes free with order)
Thanks,
Jackson
What's the build?
haha stupid me... now look
i still dont think we can see your build just copy and paste it
And if u are willing to this is a good build but its $750 but u could easily nock off the keyboard and mouse and save $80
CPUAMD A10-5800K 3.8GHz Quad-Core$119.99
CPU CoolerCooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing$28.98
MotherboardASRock FM2A75M-DGS Micro ATX FM2$44.99
MemoryG.Skill Ares Series 8GB (2 x 4GB) DDR3-2133$60.99
StorageWestern Digital Caviar Blue 1TB 3.5" 7200RPM$69.99
CaseMSI IN-623 (Black) ATX Mid Tower$39.99
Power SupplyCorsair 500W ATX12V$41.98Optical DriveAsus DRW-24B1ST/BLK/B/AS DVD/CD Writer$24.98
MonitorAsus VH236H 23.0"$139.99
Operating SystemMicrosoft Windows 7 Home Premium SP1 (64-bit)$91.99
KeyboardRazer Arctosa$40.24
MouseRazer DeathAdder Wired Laser$46.00
Total:  $750.11
Total £471.16 (I think)
plus this ram--- http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
(http://pcpartpicker.com/parts/partlist/) <--- this link comes up with a blank partlist with no parts :O
Thats wierd Ill copy and paste::
CPU:  http://www.newegg.com/Product/Product.aspx?Item=N82E16819113286
CASE:  http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
GPU:  http://www.newegg.com/Product/Product.aspx?Item=N82E16814150604
MOTHERBOARD:  http://www.newegg.com/Product/Product.aspx?Item=N82E16813128519
RAM:  http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
PSU:  http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028
i take it u have your os and storage sorted ?
yeah 1TB Western Digital Black Caviar.
It wasn't working becuase you are copying a generic link to pcpartpicker, meaning that we all see our pcpartpicker page when you paste it, under "system build" on the top bar click there, then copy the thing that says "permalink:" the link after that is the one you have to give us for the page :)
Ok thanks here it is:: http://pcpartpicker.com/p/ovNb
looks alot like mine i posted a week ago :P
http://pcpartpicker.com/p/mRrW
