Here I just want a second look on this build everything is pretty much said in the title.
http://ca.pcpartpicker.com/p/C00A
Thanks~!
Thanks~!
It looks like a solid system but I have some questions and reccomendations.
1. What is this system being used for?
2. If you want some more boot speed i'd reccomend getting a SSD like a Samsung 840 or a Kingston Hyper X
3. In the case of H100i it has a corsair link software included and if you get a compatiable PSU than you can monitor that with the software.
Otherwise it looks like a good system to me the only thing that you might want a second opnion about is the monitor because i don't get a new one unless i need one, I don't pay much attention to them.
http://pcpartpicker.com/p/C0A6
Yes? A 7970 would work too haha, and you could probably find one for a good price.
Yeah.. looks pretty good. You may want to swap out some parts though unless you really need them.
1) Listen to Lman and consider getting a SSD, unless you really really really need the storage space. It seems like you may be going for RAID0 with your system; keep a backup if you do.
The h100i is a great water cooler but is excessive unless you are planning to OC to a modestly high clock. You may be able to afford the SSD if you get a cheaper cooler and maybe get a cheap PSU (850 watts seems a bit overkill for an I5 and GTX 670).
Have fun gaming with your awesome system :)
This is a pretty good build.
ya i also agree. you can try for a ssd
i think a good 650-700w psu would suffice
Yea id be running it in raid0 im not sure about the ssd yet in main system i run a hyperx and its great but i think ill need the storage also yea i might change out the psu i forgot about corsair link aha and yea im overclocking it pretty high.
thanks for all the feedback!
