Power Supply: XFX ProSeries 750W 80 PLUS Silver Certified ATX12V / EPS12V Power Supply ($98.39 @ NCIX US)
Optical Drive: Sony AD-7280S-0B DVD/CD Writer ($25.97 @ Newegg)
Total: $1299.79
Now, I'm totally up for changing things around if I'm not getting the most bang for my buck. I'm sure some of the tech whizzes on this forum could help me out, I've never actually made a computer before!
Some things I were considering:
-Faster ram (is my current ram going to slow my gaming down?)
-A different video card (such as the Sapphire Radeon HD 7970 GHz edition 6GB for $579 or the XFX Radeon HD 7970 GHz edition 3GB for $419, which of these options is the best?)
Anything that you guys could do to help me out would be greatly appreciated and any input is welcome.
ram speed isnt a huge deal, you will see no day to day difference between 1333MHz memory and anything above, so get whats cheaper. Anything over 8GB ram is overkill for a gaming system (im assuming it's a gaming system). 750W is a bit high for a single GPU, but if you plan to crossfire in the future that is a really solid supply, personally for a single GPU system, i would go for ~600W like http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028
Are you set on the asrock, its a good board but you can get a bit more if your willing to spend a little bit more, or maybe go to a 256Gb SSD and a 1TB HDD or something along those lines ?
Well personally i try to buy the most durable components i can find, a Gigabyte Ultra Durable board is in the same price range as the other boards, like Mine has a Sata Connector by the PCI-E lanes for extra power for Crossfiring/Sli, depends on what your needs are.
these are all based on personal gripes though as a friend of mine had a Bad expirence with an Asrock Board, that beinf said it wasnt the Extreme 4 so i have no idea.
And to add something about the GPU, you dont really Need a GHZ edition when you can get a Normal 7970 and Oc it to over 1000Mhz, will save you some money.
For the most part you wont see a difference until you need 3Gb or more of Vram, which would take a MultiMonitor setup or a High-Res display with High-Res textures to use all of that, id only go with the 6Gb if you were going to Crossfire and go Multimonitor and dont plan on ungrading for a long time.
Thanks BeyondNight and everyone else, you've been extremely helpful. Would anyone change anything about the SSDs (brand or anything) or the HDD (Does my specific hard drive have a high failure rate?)
Hate to change up the build again but I got a little more money and am looking to turn this into a mid grade PC. Can you run two 7970s in the Fractal Design R4? or will there be space and heat issues?
