Hello everyone, here I am again with another Raspberry topic (who would've guess that, huh?)
I'm a bit in a blind spot right now because I don't know how or what to do: I bought an Enermax EB308S-B to use a 500GB HDD on my Raspberry. The disk is not being mounted (a generic USB2.0 drive FAT32 gets mounted automagically) but I can see it in the output of the lsusb command.
Here's the output:
Bus 001 Device 005: ID 174c:55aa ASMedia Technology Inc. ASMedia 2105 SATA bridge
(along with all the other jazz connected to it)
Also here's the dmesg output:
(might be helpful I hope)
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.19-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #858 SMP Tue Mar 15 15:56:00 GMT 2016
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[ 0.000000] cma: Reserved 8 MiB at 0x36400000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 225280
[ 0.000000] free_area_init_node: node 0, pgdat 80880fc0, node_mem_map b5c44000
[ 0.000000] Normal zone: 1980 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 225280 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (9420->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 12 pages/cpu @b6fb1000 s20416 r8192 d20544 u49152
[ 0.000000] pcpu-alloc: s20416 r8192 d20544 u49152 alloc=12*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 223300
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=720 bcm2708_fb.fbheight=480 bcm2709.boardrev=0xa01041 bcm2709.serial=0xd7a0f6e smsc95xx.macaddr=B8:27:EB:7A:0F:6E bcm2708_fb.fbswap=1 bcm2709.uart_clock=3000000 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 874420K/901120K available (6064K kernel code, 534K rwdata, 1664K rodata, 444K init, 757K bss, 18508K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xb7800000 - 0xff000000 (1144 MB)
lowmem : 0x80000000 - 0xb7000000 ( 880 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x807945f0 (7730 kB)
.init : 0x80795000 - 0x80804000 ( 444 kB)
.data : 0x80804000 - 0x80889b10 ( 535 kB)
.bss : 0x8088c000 - 0x809497dc ( 758 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Additional per-CPU info printed with stalls.
[ 0.000000] NR_IRQS:608
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000012] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000035] Switching to timer-based delay loop, resolution 52ns
[ 0.000321] Console: colour dummy device 80x30
[ 0.001530] console [tty1] enabled
[ 0.001586] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.001664] pid_max: default: 32768 minimum: 301
[ 0.002051] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002105] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.003383] Initializing cgroup subsys blkio
[ 0.003455] Initializing cgroup subsys memory
[ 0.003512] Initializing cgroup subsys devices
[ 0.003567] Initializing cgroup subsys freezer
[ 0.003630] Initializing cgroup subsys net_cls
[ 0.003736] CPU: Testing write buffer coherency: ok
[ 0.003847] ftrace: allocating 20313 entries in 60 pages
[ 0.053013] CPU0: update cpu_capacity 1024
[ 0.053089] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.053131] [bcm2709_smp_prepare_cpus] enter
[ 0.053287] Setting up static identity map for 0x8240 - 0x8274
[ 0.055842] [bcm2709_boot_secondary] cpu:1 started (0) 18
[ 0.056279] [bcm2709_secondary_init] enter cpu:1
[ 0.056338] CPU1: update cpu_capacity 1024
[ 0.056346] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.056934] [bcm2709_boot_secondary] cpu:2 started (0) 17
[ 0.057290] [bcm2709_secondary_init] enter cpu:2
[ 0.057323] CPU2: update cpu_capacity 1024
[ 0.057332] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.057877] [bcm2709_boot_secondary] cpu:3 started (0) 17
[ 0.058134] [bcm2709_secondary_init] enter cpu:3
[ 0.058163] CPU3: update cpu_capacity 1024
[ 0.058172] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.058266] Brought up 4 CPUs
[ 0.058377] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.058410] CPU: All CPU(s) started in HYP mode.
[ 0.058440] CPU: Virtualization extensions available.
[ 0.059464] devtmpfs: initialized
[ 0.083147] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.083494] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.084708] pinctrl core: initialized pinctrl subsystem
[ 0.085521] NET: Registered protocol family 16
[ 0.091199] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.092446] bcm2709.uart_clock = 3000000
[ 0.097260] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.097322] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.097545] Serial: AMBA PL011 UART driver
[ 0.097763] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
[ 0.598445] console [ttyAMA0] enabled
[ 0.602703] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.678323] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0xf35
[ 0.687056] bcm2708-dmaengine 3f007000.dma: Initialized 7 DMA channels (+ 1 legacy)
[ 0.695450] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
[ 0.702366] bcm2708-dmaengine 3f007000.dma: dma_debug:0
[ 0.708329] SCSI subsystem initialized
[ 0.712340] usbcore: registered new interface driver usbfs
[ 0.717965] usbcore: registered new interface driver hub
[ 0.723431] usbcore: registered new device driver usb
[ 0.729207] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-03-15 14:47
[ 0.764732] Switched to clocksource arch_sys_counter
[ 0.818620] FS-Cache: Loaded
[ 0.821897] CacheFiles: Loaded
[ 0.836314] NET: Registered protocol family 2
[ 0.841966] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.849202] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.855867] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.862368] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.868390] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.875240] NET: Registered protocol family 1
[ 0.880034] RPC: Registered named UNIX socket transport module.
[ 0.886015] RPC: Registered udp transport module.
[ 0.890739] RPC: Registered tcp transport module.
[ 0.895476] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.903161] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.912709] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.935000] VFS: Disk quotas dquot_6.6.0
[ 0.939333] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.948882] FS-Cache: Netfs 'nfs' registered for caching
[ 0.955393] NFS: Registering the id_resolver key type
[ 0.960523] Key type id_resolver registered
[ 0.964759] Key type id_legacy registered
[ 0.971585] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.979248] io scheduler noop registered
[ 0.983204] io scheduler deadline registered (default)
[ 0.988722] io scheduler cfq registered
[ 0.995182] BCM2708FB: allocated DMA memory f6800000
[ 1.000199] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 1.012402] Console: switching to colour frame buffer device 90x30
[ 1.024889] Serial: 8250/16550 driver, 0 ports, IRQ sharing disabled
[ 1.034455] vc-cma: Videocore CMA driver
[ 1.040337] vc-cma: vc_cma_base = 0x00000000
[ 1.046943] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.054195] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.061675] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 1.089332] brd: module loaded
[ 1.103260] loop: module loaded
[ 1.109360] vchiq: vchiq_init_state: slot_zero = 0xb6880000, is_master = 0
[ 1.120064] Loading iSCSI transport class v2.0-870.
[ 1.127793] usbcore: registered new interface driver smsc95xx
[ 1.135496] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.343434] Core Release: 2.80a
[ 1.348425] Setting default values for core params
[ 1.355089] Finished setting default values for core params
[ 1.562923] Using Buffer DMA mode
[ 1.568073] Periodic Transfer Interrupt Enhancement - disabled
[ 1.575734] Multiprocessor Interrupt Enhancement - disabled
[ 1.583122] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.589334] Dedicated Tx FIFOs mode
[ 1.595040] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xb6814000 dma = 0xf6814000 len=9024
[ 1.608754] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
[ 1.632982] dwc_otg: Microframe scheduler enabled
[ 1.633058] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x80417288
[ 1.640922] WARN::hcd_init_fiq:413: FIQ ASM at 0x804175f8 length 36
[ 1.649160] WARN::hcd_init_fiq:438: MPHI regs_base at 0xb789a000
[ 1.657113] dwc_otg 3f980000.usb: DWC OTG Controller
[ 1.663982] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 1.673277] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
[ 1.680847] Init: Port Power? op_state=1
[ 1.686680] Init: Power Port (0)
[ 1.691995] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.700712] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.709848] usb usb1: Product: DWC OTG Controller
[ 1.716435] usb usb1: Manufacturer: Linux 4.1.19-v7+ dwc_otg_hcd
[ 1.724324] usb usb1: SerialNumber: 3f980000.usb
[ 1.731730] hub 1-0:1.0: USB hub found
[ 1.737451] hub 1-0:1.0: 1 port detected
[ 1.743655] dwc_otg: FIQ enabled
[ 1.743668] dwc_otg: NAK holdoff enabled
[ 1.743678] dwc_otg: FIQ split-transaction FSM enabled
[ 1.743720] Module dwc_common_port init
[ 1.744098] usbcore: registered new interface driver usb-storage
[ 1.752272] mousedev: PS/2 mouse device common for all mice
[ 1.760588] bcm2835-cpufreq: min=600000 max=1000000
[ 1.767665] sdhci: Secure Digital Host Controller Interface driver
[ 1.775687] sdhci: Copyright(c) Pierre Ossman
[ 1.782116] sdhost: log_buf @ b6813000 (f6813000)
[ 1.864773] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 1.872355] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.900579] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.908769] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.916314] usbcore: registered new interface driver usbhid
[ 1.923740] usbhid: USB HID core driver
[ 1.929958] Initializing XFRM netlink socket
[ 1.934886] Indeed it is in host mode hprt0 = 00021501
[ 1.943068] NET: Registered protocol family 17
[ 1.948237] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.951674] mmc0: new high speed SDHC card at address 0001
[ 1.966847] Key type dns_resolver registered
[ 1.973443] Registering SWP/SWPB emulation handler
[ 1.980551] mmcblk0: mmc0:0001 00000 29.8 GiB
[ 1.981176] registered taskstats version 1
[ 1.981438] vc-sm: Videocore shared memory driver
[ 1.981450] [vc_sm_connected_init]: start
[ 1.987337] [vc_sm_connected_init]: end - returning 0
[ 2.013909] mmcblk0: p1 p2
[ 2.046818] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.058794] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.068610] devtmpfs: mounted
[ 2.074244] Freeing unused kernel memory: 444K (80795000 - 80804000)
[ 2.114788] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.123480] Indeed it is in host mode hprt0 = 00001101
[ 2.325150] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.334018] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.344249] hub 1-1:1.0: USB hub found
[ 2.350284] hub 1-1:1.0: 5 ports detected
[ 2.571886] random: systemd urandom read with 63 bits of entropy available
[ 2.585956] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 2.604156] systemd[1]: Detected architecture 'arm'.
[ 2.634801] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.755165] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.764265] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.776858] smsc95xx v1.0.4
[ 2.808359] NET: Registered protocol family 10
[ 2.818550] systemd[1]: Inserted module 'ipv6'
[ 2.829513] systemd[1]: Set hostname to .
[ 2.842101] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:7a:0f:6e
[ 2.924281] uart-pl011 3f201000.uart: no DMA platform data
[ 2.954801] usb 1-1.4: new high-speed USB device number 4 using dwc_otg
[ 3.076386] usb 1-1.4: New USB device found, idVendor=0bda, idProduct=8178
[ 3.085547] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.095064] usb 1-1.4: Product: USB WLAN
[ 3.101109] usb 1-1.4: Manufacturer: 802.11n
[ 3.107498] usb 1-1.4: SerialNumber: 00e04c000001
[ 3.369369] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 3.379830] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.389710] systemd[1]: Expecting device dev-ttyAMA0.device...
[ 3.400429] systemd[1]: Starting Remote File Systems (Pre).
[ 3.410696] systemd[1]: Reached target Remote File Systems (Pre).
[ 3.419068] systemd[1]: Starting Encrypted Volumes.
[ 3.428616] systemd[1]: Reached target Encrypted Volumes.
[ 3.436334] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[ 3.452640] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.466742] systemd[1]: Starting Swap.
[ 3.475448] systemd[1]: Reached target Swap.
[ 3.481997] systemd[1]: Expecting device dev-mmcblk0p1.device...
[ 3.492820] systemd[1]: Starting Root Slice.
[ 3.501987] systemd[1]: Created slice Root Slice.
[ 3.508998] systemd[1]: Starting User and Session Slice.
[ 3.519411] systemd[1]: Created slice User and Session Slice.
[ 3.527465] systemd[1]: Starting Delayed Shutdown Socket.
[ 3.537832] systemd[1]: Listening on Delayed Shutdown Socket.
[ 3.545863] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 3.557490] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 3.566796] systemd[1]: Starting Journal Socket (/dev/log).
[ 3.577453] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.585746] systemd[1]: Starting udev Control Socket.
[ 3.595657] systemd[1]: Listening on udev Control Socket.
[ 3.603227] systemd[1]: Starting udev Kernel Socket.
[ 3.612755] systemd[1]: Listening on udev Kernel Socket.
[ 3.620260] systemd[1]: Starting Journal Socket.
[ 3.629594] systemd[1]: Listening on Journal Socket.
[ 3.636772] systemd[1]: Starting System Slice.
[ 3.645975] systemd[1]: Created slice System Slice.
[ 3.653029] systemd[1]: Starting File System Check on Root Device...
[ 3.667316] systemd[1]: Starting system-systemd\x2dfsck.slice.
[ 3.678788] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 3.687397] systemd[1]: Starting system-getty.slice.
[ 3.697822] systemd[1]: Created slice system-getty.slice.
[ 3.705768] systemd[1]: Starting system-serial\x2dgetty.slice.
[ 3.716647] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 3.725271] systemd[1]: Starting Increase datagram queue length...
[ 3.739740] systemd[1]: Starting Restore / save the current clock...
[ 3.759560] systemd[1]: Mounted Huge Pages File System.
[ 3.805562] systemd[1]: Starting Load Kernel Modules...
[ 3.819779] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.875278] systemd[1]: Started Set Up Additional Binary Formats.
[ 3.884856] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 3.905751] systemd[1]: Mounting Debug File System...
[ 3.920001] systemd[1]: Starting udev Coldplug all Devices...
[ 3.930684] fuse init (API version 7.23)
[ 3.942453] systemd[1]: Starting Slices.
[ 3.951668] systemd[1]: Reached target Slices.
[ 3.965565] systemd[1]: Mounted Debug File System.
[ 3.976599] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.987468] i2c /dev entries driver
[ 3.995733] systemd[1]: Started Increase datagram queue length.
[ 4.022229] systemd[1]: Started Restore / save the current clock.
[ 4.035310] systemd[1]: Started Load Kernel Modules.
[ 4.047399] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 4.084582] systemd[1]: Time has been changed
[ 4.142205] systemd[1]: Started udev Coldplug all Devices.
[ 4.168610] systemd[1]: Started File System Check on Root Device.
[ 4.308916] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 4.325125] systemd[1]: Mounting Configuration File System...
[ 4.340005] systemd[1]: Starting Apply Kernel Variables...
[ 4.355824] systemd[1]: Mounting FUSE Control File System...
[ 4.370828] systemd[1]: Starting Syslog Socket.
[ 4.381971] systemd[1]: Listening on Syslog Socket.
[ 4.382230] systemd[1]: Starting Journal Service...
[ 4.393682] systemd[1]: Started Journal Service.
[ 4.568196] systemd-udevd[108]: starting version 215
[ 5.250473] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 5.483113] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 6.023713] random: nonblocking pool is initialized
[ 6.057002] usbcore: registered new interface driver rtl8192cu
[ 6.251382] bcm2835-rng 3f104000.rng: hwrng registered
[ 6.416673] systemd-journald[106]: Received request to flush runtime journal from PID 1
[ 7.179803] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 7.549019] cfg80211: Calling CRDA to update world regulatory domain
[ 7.688843] Adding 102396k swap on /var/swap. Priority:-1 extents:2 across:1781756k SSFS
[ 7.783928] cfg80211: World regulatory domain updated:
[ 7.783949] cfg80211: DFS Master region: unset
[ 7.783957] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 7.783968] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.783978] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.783987] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.783998] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 7.784009] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 7.784019] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 7.784028] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.784037] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 9.309258] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 9.309678] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.426609] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 10.724887] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
[ 10.867371] usb 1-1.3: New USB device found, idVendor=174c, idProduct=55aa
[ 10.867394] usb 1-1.3: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 10.867404] usb 1-1.3: Product: ASMT1051
[ 10.867414] usb 1-1.3: Manufacturer: asmedia
[ 10.867423] usb 1-1.3: SerialNumber: 75NDBMMBS000
[ 10.868406] usb-storage 1-1.3:1.0: USB Mass Storage device detected
[ 10.869234] usb-storage 1-1.3:1.0: Quirks match for vid 174c pid 55aa: 400000
[ 10.869407] scsi host0: usb-storage 1-1.3:1.0
[ 12.223612] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 33.385040] usb 1-1.3: reset high-speed USB device number 5 using dwc_otg
Thanks for whoever will answer me. Everyone here has always been helpful and kind here, that's why I keep asking you guys.
