Raspberry pi running a nintendo DS screen?
Is it possible to get raspberry pi to display on a Nintendo DS screen? Or is there something close that i can get to replace it that would work well and not draw a ton of power.
emulator for android...... i guess?
nope. Portable computer and game emulator....well i guess i could use android
So getting the pi to output to a nintendo ds screen? Hmmmmm
I'm not to sure. The problem is that the screen is using a proprietary driver that is designed to only to be used with the DS. Try looking around for part numbers and the corresponding data sheets.
http://www.adafruit.com/products/1601
