Looking for an adapter or someone that can make an adapter to make the Steamdeck OLED screen work with a rasbery Pi4B any help would be appreciated, I have about 10 projects i would like to do that having this as the control setup be perfect.
So did some quick googling and using my education (EE degree). I would recommend just buying a screen built for the raspberry pi. From just cursory look at the Steam deck OLED screen and that of a raspberry pi compatible screen. You’d need to create a new daughter board similar to the one Raspberry has made for their solution. Not impossible, but the amount of work and effort would be quite high so I would find this highly unlikely to be made by a third party and the cost to have this made professionally would be considerable.
You could roll the dice on something like this: Amazon.com
I had looked at that but for what im wanting 7 to 7.5 inch is the size i requierd that’s why i was thinking the Steamdeck screen, as i cannot find any OLED screens that are touch and 7 to 7.5 inch,
If i was’nt after a specific size that would be perfect.
Understood, well good luck in your search. Hopefully a solution exists out there for you.
