Problem is that your CPU is probably throttling, your motherboard has not heatsinks on the VRM meaning that the VRMs are most likely overheating and cause it to throttle. I would recommend upgrading your motherboard ASAP to something like a M5A99X EVO or you can try to under clock your CPU so it doesn't pull so much power. Also 65°C is way too hot for an FX CPU, the max safe temps for the FX line is 61°C so you need a better CPU cooler as well
42°C for the motherboard is really hot, you might need to look into after market heatsinks as a temporary fix until you get a new properly heatsinked motherboard, you will also need to underclock/undervolt your CPU to bring your temps down. You are running too hot
That should work but remember to try to bring you core voltage down as much as possible while keeping everything stable and keeping the speed you want. The lower the core voltage the cooler things will be.
Why did you buy the FX-9370...That's your problem. You're running a REALLY demanding CPU with a motherboard that can't handle it properly. I definitely recommend either something along the lines of a Gigabyte 990FXA-UD3/ ASUS M599FX EVO/PRO. 970 chipset can't handle that kind of clock speeds so its running on overtime. Also, the CPU cooler is in question. To run at those clock speeds you're going to need to do an upgrade as well on the cooler. That H70 is horrible performance, you literally got bottom of the barrel AIO liquid cooling. I definitely suggest if you wanna stay AIO to at least get an H100i or higher. If you're going air cooled, the Noctua NH-D14/15. I think you should've read up on the CPU specs a little more. AMD during the beginning of their marketing for the FX-9xxx they were saying that you MUST buy the CPU with one of their selected motherboards to even purchase the CPU. Hopefully that helps a bit.
Switch back to your old processor or get a new motherboard. You need to be underclocking that processor to Fx 6300 voltages or not use it at all. Your motherboard isn't capable of running a 8350 stably, no where near a 9370.
