RANDOM BSODs for different reasons
I ve had so many BSODs and i just rather upload the memorydump, so you guys can take a look.
I ve had to rma my gpu, my hardrive, loaded os to ssd, various reinstalls and i still have these problems. I ve also performed memtest and 20 passes no errors found.
Please help this is so irritating.
also if i try to verify all my current drivers. I get an bsod and i cant load into the os (driver verifier).
https://mega.co.nz/#!HgllRISb!lLP4nUf73UKRw9Ie_NBMCOqNqE6id9AwOvQCMznS_y8
I've not looked at the memory dump yet but in my experience BSOD usually boil down to;
1) A very bad (unsigned) driver
2) Damaged or incorrectly installed components
3) Overclocking with incorrect settings or just going a bit too far
4) Bad or incorrectly installed memory e.g. it's in the wrong slots or different types have been mixed.
Out of all of those number 4 has been the one I've come across the most.
I'll see if I can take a look at the dump later on today, but if anyone else can that would be great.
If you have not tested your RAM one stick at a time I suggest that is what you try next.(edit; I know you have done memtest but its still worth double checking)
Here is the output from KD.exe:
* Bugcheck Analysis *
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff8035d6aed54, Address of the instruction which caused the bugcheck
Arg3: ffffd00026425ef0, Address of the context record for the exception that cau
sed the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced me
mory at 0x%08lx. The memory could not be %s.
FAULTING_IP:
nt!KiInsertTimerTable+204
fffff803`5d6aed54 4d3b7ef8 cmp r15,qword ptr [r14-8]</p><p>CONTEXT: ffffd00026425ef0 -- (.cxr 0xffffd00026425ef0;r)<br />rax=000000000002e763 rbx=0000000000000000 rcx=0000000000009896<br />rdx=0000000b7a20c43e rsi=fffff8035d981280 rdi=ffffe001752ac180<br />rip=fffff8035d6aed54 rsp=ffffd00026426920 rbp=fffff8035d981288<br /> r8=ffffe00174ca79a0 r9=0000000000000088 r10=fffff8035d67a000<br />r11=fffff78000000008 r12=fffff8035d97ff80 r13=0000000000000088<br />r14=f7ffe00175a151a0 r15=0000000b7a23aba1<br />iopl=0 nv up ei ng nz ac po cy<br />cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010297<br />nt!KiInsertTimerTable+0x204:<br />fffff803`5d6aed54 4d3b7ef8 cmp r15,qword ptr [r14-8] ds:002b:f7ffe001
`75a15198=????????????????<br />Last set context:<br />rax=000000000002e763 rbx=0000000000000000 rcx=0000000000009896<br />rdx=0000000b7a20c43e rsi=fffff8035d981280 rdi=ffffe001752ac180<br />rip=fffff8035d6aed54 rsp=ffffd00026426920 rbp=fffff8035d981288<br /> r8=ffffe00174ca79a0 r9=0000000000000088 r10=fffff8035d67a000<br />r11=fffff78000000008 r12=fffff8035d97ff80 r13=0000000000000088<br />r14=f7ffe00175a151a0 r15=0000000b7a23aba1<br />iopl=0 nv up ei ng nz ac po cy<br />cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010297<br />nt!KiInsertTimerTable+0x204:<br />fffff803`5d6aed54 4d3b7ef8 cmp r15,qword ptr [r14-8] ds:002b:f7ffe001
`75a15198=????????????????<br />Resetting default scope</p><p>DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT</p><p>BUGCHECK_STR: 0x3B</p><p>PROCESS_NAME: Zona.exe</p><p>CURRENT_IRQL: 2</p><p>ANALYSIS_VERSION: 6.3.9600.17237 (debuggers(dbg).140716-0327) x86fre</p><p>LAST_CONTROL_TRANSFER: from fffff8035d6ad29d to fffff8035d6aed54</p><p>STACK_TEXT:<br />ffffd000`26426920 fffff803`5d6ad29d : ffffe001`752ac080 ffffd000`26426b80 000000<br />00`0002de87 fffff803`5da5e647 : nt!KiInsertTimerTable+0x204<br />ffffd000`26426980 fffff803`5d6d3ac0 : ffffe001`751a79f0 00000000`00000000 000000<br />00`00000088 00000000`777d1b10 : nt!KiCommitThreadWait+0x1bd<br />ffffd000`26426a00 fffff803`5da5e4a2 : ffffe001`74fed200 ffffd000`00000006 000000<br />00`00000000 fffff803`00000002 : nt!KeWaitForSingleObject+0x2c0<br />ffffd000`26426a90 fffff803`5d7d62b3 : ffffe001`752ac080 00000000`00000000 ffffd0<br />00`26426ad8 ffffe001`74fed200 : nt!NtWaitForSingleObject+0xb2<br />ffffd000`26426b00 00000000`777d2352 : 00000000`00000000 00000000`00000000 000000<br />00`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13<br />00000000`3debea88 00000000`00000000 : 00000000`00000000 00000000`00000000 000000<br />00`00000000 00000000`00000000 : 0x777d2352</p><p><br />FOLLOWUP_IP:<br />nt!KiInsertTimerTable+204<br />fffff803`5d6aed54 4d3b7ef8 cmp r15,qword ptr [r14-8]
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: nt!KiInsertTimerTable+204
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 545167e0
STACK_COMMAND: .cxr 0xffffd00026425ef0 ; kb
BUCKET_ID_FUNC_OFFSET: 204
FAILURE_BUCKET_ID: 0x3B_VRF_nt!KiInsertTimerTable
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:0x3b_vrf_nt!kiinserttimertable
FAILURE_ID_HASH: {fe4d5100-313d-2265-e2de-4003abc86038}
Followup: MachineOwner
Whatever zona.exe is I would get rid of it!
If you have performed windows rebuilds I suggest you virus scan all your drivers and any installation media. Zona.exe is not a windows process so should not be present on a fresh rebuild.
EDIT: I should make it clear that I am not 'the expert' on all this so if someone else spots something else in that analysis feel free to correct :-)
2nd EDIT: This is obvious and I can't believe I haven't put it in, but have you checked for BIOS updates and reset your BIOS back to safe defaults? If the BSOD reoccurs after you have got rid of that Zona.exe  - you should definitely check your BIOS as well as RAM configurations.
