Rampage 4 extreme error 34?
I'm getting some beeps and error code 34. Anyone know? I have it down to one stick of ram. No hard drives connected. The setup worked with my old titan but not the new one. I will try a reseat as a last option. I'm on hold for asus tech. I've also reset the cmos
Have you hit memok already? Clear cmos?
From what I found, 34 is the debug code shown when you stop post and go into BIOS. So what's shown on your screen?
Haven't tried that? I'll have to find where the memok button is
It makes the beeps at 97 of that helps but then lands and stays at 34
Nothing is shown on screen
From what I read... google.com for the win. It seems as if your GPU is not outputing anything and you motherboard just entered the bios.
34 says => I am done posting, dear user you entered the bios. So its normal that it stays there, until you exit the bios.
Maybe your GPU is outputing on another interface than you have your screen plugged in?
It might help to plug in the 8 pin to gpu ;)
Totally! They did not put that there just to wast 50c on the connector :P
