RAM Timing Questions
I’m looking to replace my RAM pending an upgrade to the Ryzen 5000 series:
Current RAM: gskill (dot) com/product/165/326/1578906066/F4-3200C16D-64GTZN
Possible replacement 1: gskill (dot) com/product/165/166/1620974215/F4-3600C14Q-64GVKA
Possible replacement 2: gskill (dot) com/product/165/299/1562839857/F4-3600C16Q-64GTZN
My questions: Would the RAM timings on possible replacement one be a significant performance uplift over the timings on possible replacement two? Would you recommend slightly looser timings to save money, say 14-15-15-35 or 16-19-19-39? My machine is used mostly for gaming, but also some light CAD and video encoding workloads.
Thanks in advance!
Upgrading just for the sake of +200Mhz and better timings is certainly not worth it. Expect results in the region of “could be a rounding issue in the benchmark” to “low single digit” differences in benchmarks.
So a 3200mhz 15-15-15-35 would be on par with a 3600mhz 14-14-14-34 or 16-16-16-36? Mind you, I’m wanting to upgrade from a two stick kit to a four stick kit for the better performance on Ryzen 5000.
Thanks for your input.
Higher frequency will increase memory bandwidth, but honestly if you’re asking, you probably won’t see any difference even though you can bench a difference going from 3200 cl14 to 3600 cl14.
TL;DR probably save your money unless you can afford to burn $300+ on a set of 2* 16GB 3600 cl14 B dies. It’s more cost effective to overclock your current set to 3600MHz.
Thank you for your input.
I personally run 3600 14-14-14-34 Ripjaw V 64Gb
I wouldn’t say that there’s a big difference vs a normal 3200cl16 kit, but certainly if you’re mostly gaming and already spending a decent chunk of money to get better performance I say every little bit helps.
For me, it wasn’t about average fps or anything, but a better kit can impact the consistency of your frame time graphs. Depends on how anal you are about that
I went from a 3900x to 5950x purely for 1% and .1% lows; I also run a custom loop…
I’m just the kind of guy that likes to milk his hardware for every ounce of performance
EDIT:
Keep in mind, that you can generally manual timings pretty well on kits much cheaper than out of the box binned kits; Micron E-Die is pretty cheap and OCs really well. Just depends on how much time you’re willing to pour into that; I’m lazy and wanted something I knew should work out of the box
I’ve never done any manual overclocking and am a bit afraid to as I don’t really have the money to replace anything if I mess up royally, so I’m willing to pay extra for an out of the box DOCP setting.
I’m not worried about average FPS either, as I play mostly single player games and put on a 120fps cap, but the frame times are important. It should also help with some of the CAD work I plan on doing from what I understand in research and reviews.
I’m going to be upgrading from a 3700x to a 5950x and using an Arctic Liquid Freezer II 360 AIO in a Phanteks P500A.
I plan on sticking with this build until the motherboard dies, so maximum performance is my goal with as little fuss as possible.
In that case, yeah, you sound like exactly the kind of person I would recommend your option 1, too.
Funnily enough, I’m pretty sure that’s the kit I’m running now with Asus Dark Hero + 5950x
I’ve beaten a heap of benchmarks (fire strike, etc.) on my 2700X vs. “similar systems” with DDR4-3000 CAS 14 - two sticks of dual-rank.
These upgrades (As above) make no sense. Save your money for something that will make more difference than slightly beyond run to run variance.
