RAM suggestions for build in progress
Hey Tekkers,
I have a build underway utilising an ASUS M5A97 EVO R2.0 and an FX-8320 (will overclock, have Hyper 212 EVO). I need to get this thing up and running in the next couple of days as I am using it to perform genomic analysis bits and pieces for my thesis (my old rig wasn't up to the task). As such, I am not in a position to order things online, my local PC store 'MSY' tends to beat out most online retailers in Australia anyhow. I really just need to find a decent 16Gb kit among those they have in stock and get to work - 16Gb being necessary as some of my scripts write to RAM and my data sets are enormous (whole human genomes).
On hand they have the following:
Patriot Viper http://msy.com.au/product.jsp?productId=9420
G.Skill Sniper http://msy.com.au/product.jsp?productId=10151
G.Skill Ripjaws X http://msy.com.au/product.jsp?productId=10149
Patriot IEM Blue http://msy.com.au/product.jsp?productId=10206
These all come in at ~$130 Australian or less, which is about what I have left to spend.
Any thoughts on what may suit me best?
I say go with the Sniper memory. Gets great reviews, and is quite low profile Which is awesome for your cooler
Well, they seem to have identical specs. I'd just go with Patriot Viper since it's (one of) the cheapest.
you need to search for memory with a low heat spreader, otherwise  you cant put this into slot 1 with that big air cooler will cover the first memory slot on the motherboard, so that make sense
http://msy.com.au/product.jsp?productId=9826
or
http://msy.com.au/product.jsp?productId=9745
or these vipers seems low to me
http://msy.com.au/product.jsp?productId=9419
or
http://msy.com.au/product.jsp?productId=10142
Thanks guys, this has been helpful!
guys? :O tsss :(  im not a guy :P grrrrr haha
Sorry Mistery! I meant guys in the androgynous sense of the word...
