RAM Replacement
So, about a 2 years ago a stick of ram died in my x99 machine, and I’ve started hitting my limit of 24GB of usage in only a few days (VMs + chrome + games). I’d been just shutting down the VMs and dealing with it, but I figured I might just be able to replace it.
Right now I’m running an MSI x99 Krait + 5930k that will not let me mix and match (won’t even post with different speed/latency in the other channel). So here’s where the question comes in:
Can I just buy another stick of equally spec’d RAM and get back to 32GB? Or am I SOL and need to drop $300+ on a new kit? I know in ye olde days I could do that, but I’m not sure if modern boards will support it.
Provided they use the same timings, yes.
But I’m wondering… RAM usually has like 10 years of warranty, why not RMA it?
Mainly because I’ve moved a few times since then, and no longer have the dead stick…and it didn’t occur to me that there was a warranty until I started running up against the 24GB limit. I was just like “ehh, i sit at like 14GB all day, 18 when I’m gaming, why would I need to go through the hassle to get it replaced?”. And then spectre, a new version of chrome, and a one more VM…and now im hosed.
Right now I have 3 sticks with the SKU “CMK32GX4M4A2666C16” and I’m looking at 1 with the SKU “CMK8GX4M1A2666C16”. If my knowledge of SKUs is still valid, I think that means the only difference is one is a 32x4 kit, and the other is 8x1. The rest of the numbers in the SKU match up.
I guess since I’m looking on amazon and their return policy is pretty lax, I could always return it if it doesn’t work out.
Well that’s rather unfortunate, but worth a shot.
And yes, those are an 8GB x4 and an 8GB x1 kit respectively. Timings are also the same. So that should be fine.
Sometimes the chips change even in production runs, but as long as they are of the same timings they should still work together.
Required a BIOS update, but now I’m back up to 32GB of RAM. Sadly had to go with advertised speeds, so back down to 2666 from 3000MHz, but it is what it is.
Thanks for the assist.
Just in case someone finds this on google. The version number on the ram modules were different, and my system didn’t not post with my Rev0 BIOS and just the 1x8GB new stick. After updating the BIOS, I was able to go in and manually set the RAM to the advertised CAS latency and speed. The XMP profiles did not work.
