Ram problems!
hey so ive been having two problems with my ram, first is i recently bought a secound dimm but my motherboard wont recognize it and also in game i get magure lag spike because of it! please help asap tanx -dmanduck
Is the Second DIMM matched with the first one? (Eg Same Speed, Latency, Capacity etc)
If it is not perfectly matched then there will be issues. If it is slower than the first, the speed of the first will be reduced to match the second.
Have you tried testing the RAM for issues with memtest?
But to me it sounds like unmatched RAM.
Hope this helps.
- zanginator
(ps magure = major)
