I'm not sure if I'm at the right place but, I have a problem with my ram.
I recently installed my vengeance 1866mhz ram and installed windows8. when I went into the bios I noticed that the ram was only clocked at 1333 mhz, so when I upped it to 1866 and restarted the pc, it didn't wanna boot into windows.
can anybody tell me what the problem here is? or if there is something I have to look at before clocking my ram?
nop, tried that, didn't work. I'm using the asus maximus v formula motherboard and I tried the "go button" still didn't work. if I'm correct, the 1866mhz vengeance ram should run 1866mhz on 1.5v right? I also thought about reinstalling windows while having the ram clocked to 1866, got errors...so, didn't work.
I think I found the problem, I had to set the timings to 9-10-9-27. it works now, but I would like to test my pc's stability. what should I use for that, prime 95?
Hey I had the same problem, I have corsair vengeance ram 1600mhz, it was running at 1333mhz, changed the frequency and I got a hardware failure, after that it would not post or beep and I'm currently waiting on my new motherboard.
