So, I built my first PC about a month ago and everything was running smoothly. Until I realized that my RAM wasn't running at the correct clock speed. My PC parts list I bought some blazing fast, awesome looking red Corsair Vengeance Pro, 32 gigs worth of it. I was fairly happy about the 2400Mhz until I realized it wasn't running at that speed.
Even in my bios it says that it's running at something like 1333Mhz, which is weird. Did some digging, saw some RAM voltage snafu with the Haswell refresh chips saying that at stock it's set to 1.5V max and that setting it to 1.65V will help the RAM run at the full speed.
So I went through and set up the XMP profile (can't believe I missed something so simple) but even with the change in the profile and the bios reading the correct speed for the RAM. Nothing else is reading that speed though.
Thanks guys, it seems that I keep forgetting the simplest things, it may just be I'm tired and worked a little over 8 hours today. Either way, thank you for indulging my mistake and helping me correct it.
