I had a question about my RAM. I overclocked my CPU in the BIOS to 4.37 GHz, and now my RAM runs at 920 mhz? RAM profile is set to 1600 mhz CL 9-9-9-24, but for some reason it keeps saying DRAM Frequency = 460 mhz. Motherboard is an Asrock 970 Extreme3 R2.0.
Thanks.
(and don't worry, a second RAM stick will be installed very soon.)
Your ram is automatically changed for sistem stability when you oc if i rember rigth on that mobo you need to set the ram to manual instead of automatic
