So my PC has been running fine for 3 months but randomly it started black screening at the BIOS every other time I boot. I tried taking it out and putting it back in, no dice. I had this problem before and fixed it by taking it out and putting it back in. I tried with some different RAM and no problem. I do not think the RAM is dead, please help!
Strange. You running off of xmp settings I am assuming? Best bet would be to run one stick at a time in different slots to rule out mobo. Otherwise, you might have to contact g.skill and rma. Heard rumours that amd doesn't always play nice with higher clocked RAM. Did you already run it through any tests?
Is that an ASUS overclocking utility? I would suggest using XMP profile, amd calls it something else. Hopefully somebody else jumps in and gives you the correct timings/ correct setting for your amd. Imma google it real quick.
