Please bare with me if this q is old I'm new here.
I'm currently trying to piece together a system (check Build a PC forum) and I'm wondering if there are any air coolers out there that don't interfere with the first two dim slots? Stock coolers not considered. I've seen that mostly the first one is blocked. Hate to think that, if later on the need to add more ram would be thwarted by the cooler.
Looks like a relatively low profile ram. Personally I have Kingston HyperX Genesis Grey and it does not have any overhead cooler so it works perfectly with big coolers like my Noctua NH-D14.
Sometimes cooler manufacturers list ram compatibility so that worth a look, failing that Google for people with the same configuration.
Got me a little confused with that pic... why is your cooler mounted that way? Doesn't that pull heat from the GPU? I thought the best way was to mount where blows out the back (fan over ram) so that excess air could flow over the ram and aid in cooling? I'm just learning all this so if I'm wrong please correct.
Well, I can see where it can work, but I was thinking more along the lines of wanting to add ram later on without the need to remove and re-install the cooler. Guess I should have made that clearer in the beginning. Sorry 'bout that.
Thanks for the info Dissentient. I wonder if the bigger ones like Notura and Phanteks would fit like that? I've read that some coolers can't be mounted @ 90d. Man, this is gonna take me longer to build than I thought.
Oh in that case yeah if you have a large cooler that overhangs and you don't populate the ram slots below it before you would likely have to remove the cooler, seat the RAM and the mount the cooler again.
I didn't know for sure if the Sniper I chose for the build was lp or not. I guess when I eventually do the build I could populate the 1st & 3rd. That way I could add on later, if need be, without issues. Thanks MA.
