I now ryzen is picky in ram, but i am a noob in that area, so you are my only hope right now!
What i now that i need is a 2 x 8gb kit, with 3200 speed, but there are so many, and idk which one is ryzen compatible. My budget for the ram is aroung 150 Euro
i looked at the official list of amd, (even though it was not updated since the firt cpu-gen, i think) and i found this ram , but then when i look at the description it says: “proccesor brand: intel” , or is that irelevant.
Edit: the model number in amazon says: CMK16GX4M2B3200C16 , and amd’s pdf says CMK16GX4M2B3200C16 v5.39
The motherboard im buying is: Asrock x470 Taichi (because i heard that is the most Linux friendly mobo.)
Ryzen especially likes RAM with Samsung B-Dies. You can find matching memory kits here: https://benzhaomin.github.io/bdiefinder/
thats super cool, i’ll check some links !
