Now I bought A10 CPU and bought a vegeance corsair running at 1866 now i don't know if they will work together because the box shows intel CPU making me think it only works with those CPUs and the guy that works in tech gave me that RAM but i didnt get to look at the case because they were holding it at the cashier so can anybody tell me will the RAM I bought work with the A10 CPU?
Yes they will work just fine the intel logo on the box is just advertising that they are compatible with intel cpu's but they work just as good on your amd a10
yes
usually any ram will work in any computer......... if it fits in the slot
