Raidmax Cases - Size?
I searched all over the raidmax website but I can't find what size the cases are. Are they all full tower or are they mixed?
Uhm, well, there's a lot of Raidmax products, and they vary. Most of them, however, are Standard ATX-Mid Tower, and I think the only other sizes of cases they make is the Katana, which is a Full Tower, and the IceCube, which is a MicroATX Mid Tower. Their more popular cases like the Smilodon, Scorpio and Saggitta series are all ATX-Mid Tower's.
Dang, its so hard to find a good full tower
go on newegg.com, and used the filters to search for fulltowers.
i think the kanata is full size atx, but theres always alot of other brands n differnt cases.
Well, here are a few good Full Towers I recommend. They're sorted by price, Low-High. You seem to be on a budget, so these are between $100-150.
Apevia MX-Pleasure
W/O Window- http://www.newegg.com/Product/Product.aspx?Item=N82E16811144135
W/ Window- http://www.newegg.com/Product/Product.aspx?Item=N82E16811144133
Enermax Uber Chakra ( I think these are CrossFire certified, if I remember )
Solid Black- http://www.newegg.com/Product/Product.aspx?Item=N82E16811124121
Black/Blue- http://www.newegg.com/Product/Product.aspx?Item=N82E16811124123
Black/Silver- http://www.newegg.com/Product/Product.aspx?Item=N82E16811124124
Apevia X-Telstar
http://www.newegg.com/Product/Product.aspx?Item=N82E16811144185
Gigabyte 3Dmars
http://www.newegg.com/Product/Product.aspx?Item=N82E16811233026
Thermaltake Armor VA8000BWS ( Probably the best Full-Tower under $150 )
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133154
Ultra M923 ( Popular Case, I wouldn't get it, but thats up to you )
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3319620&CatId=1510
NZXT Zero ( Widely regarded as the best case for stock cooling and price )
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146029
Does this case have good cooling? I see it doesn't have a top fan but the side should be good enough I think.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811144205
Oh yeah, that should be good. Not as good as the NZXT Zero I wouldn't think, but good enough with those two 120mm rear exhaust fans and that 250mm(seems like it would be an intake, but I can't be sure). And I love the gauges/LCD temperature readouts Apevia puts on their cases.
Yeah I love how you can change both the intake and exhaust fans on that case
