Created a raid zero on the Asus crosshair AMD board with a 3950X. The raid is not showing in windows for installation. ASUS is not able to help and has escalated it to a level 2.
Any suggestions?
Any suggestions?
Any more details you can share?
Just got off the phone with Asus. They just mentioned something about loading a driver, I’m going to go do that now. It’s the 860 evos 1 TB.
The drives show up in bio says raid
Ok so SATA drives so windows should be able to see them if you install the raid xpert driver
Should be in here. Or check your motherboard manual for installation instructions
Worked right away, thx.
