So just would like to know when happens if you are running a good Raid card and it fails the drives are useing a SAS cable what will have to the aray of drive when you replace or fix the card will you just have to plug the the cables in to the new or fixed card and it will workand the aray is fine or will you have to reset up the raid and losse your data or if you are just useing them as inderival disks not in raid
to put it simplay withat will happen to you drives and data if your raid card dies
wanting to know cos i am trying to work out the best way to store all the data i have
thank you for any help
