Dear All, I’m hoping someone can help me.
I have a file server in our small office which I set up with Windows Server 2019 essentials. I repurposed a small old intel 3rd gen machine by putting 5 ssds in it. One ssd is for boot, the other 4 were set up as a software raid 5 ReFS using disk manager in windows. It keeps database data for clients’ financial files which computers on the network can access.
I have an UPS connected to it, which showed as healthy through the software and is only a year and a half old, with load only around 10%, however we had a power outage in the area and generally unstable electricity for a few days here and the UPS didn’t keep the computer on long enough for a graceful shutdown; only a few seconds and off. This unfortunately happened a few times with the electricity here.
When I’ve checked the disks in disk manager, it first showed the disks resynching as expected. However after some time, it stopped with errors and then with the message on the array as ‘at risk’. One of the disks has an exclamation mark next to it, and when I went to reactivate to try to resynch, after some time I get the same error. A restart did not help.
I’ve checked event viewer and under windows logs → system, there are multiple error entries with the description: The device, \Device\Harddisk3\DR3, has a bad block. Also, on the regular backup of data from the array to the NAS, windows backup gives an error for one file with the description: Error in backup of Z:\Data\Sage Data\Payroll\Company_049\ARCHIVE\W19072020_16-13-36.001 during read: Error [0x80070017] Data error (cyclic redundancy check).
My question is if I bring this disk 3 ‘offline’ through disk manager, wipe it, check disk it to ‘repair’ the bad blocks, and then reassociate it with the raid5 array, can this work? Is this a viable solution?
In the meantime, I have ordered a couple of more SSDs to arrive tomorrow so I can add it to the system if it needs replacing.
Should I be doing anything else? My data does have a backup, but I’d rather not have to wipe everything and restore if I can possibly help it.
Many thanks for the time of anybody who reads and replies.
