Hey guys, I am building a workstation PC soon, and I was wondering if 4 128GB SSD (Samsung 840 EVO) in RAID 0 would be faster than 2 256GB in RAID 0 or a single 512GB SSD. All answers are appreciated, thankyou! And if you think something will work better than this please say!
I believe that 4 SSDs in RAID 0 would be faster than a single or 2 SSDs in RAID 0 as the data is stored across the 4 SSDs. In theory, as the data is spread across the 4 drives, 4 times as much data can be accessed in one cycle. So if I were you, if access speeds are important to you, I would go for the 4 SSD in RAID 0 setup.
performance double going from 1 to 2 drives, triples from 1 to 3, but adding another drive doesn't really make a difference anymore when you run this of the intel sata controller. you will need a raidcard to make it take the performance out of the 4th and further drives.
Too small drives and you sacrifice write speed because of the lower number of flash chips. Settle for 2 x 250GB of those drives for a nice balance of things.
Just going to say that using RAID0 is careless because the possibility of total data lost doubles with identical drives and is even higher with different drives. A solution would be to use RAID10 if you have enough money.
