Id like to find out what issues lie around RAID and linux using the later z170 and z370 chipsets with Intel vs AMD processors.
I am interested in upgraded some components or basically trading the part for a certain feature, in this case, I’d like to get two m.2 slots on my mobo. I only have one atm, I am aware there are adapters, and am wiling to go that route instead of trading the mobo. In any case, there are a few videos of z170 nvme raid 0 with intel and a few with amd, most are older and seems to have some issues or concerns at that time.
Im wondering what has changed in the last two years here… I have not yet found much recent developments on the older tech, just raid with z370 chipset mobos… and I dont have the money for four 960’s … lol
Another thing Id like to discover is if the performance scales with the # of drives installed in the array? Ill google again for some refreshing on the basics of raid. So will two drives work as fast as four drives, in which four drives would just have more storage, or does every drive add performance in the array, meaning I assume to a point: more is better?
In that case, where is the limit. Any videos of a comprehensive benchmark with intel vs amd using raid 0 with the 970 evo vs pro?
Im just starting on the idea of RAID and if its not wise to invest now, Ill invest in the next build, either a later 370 or upcoming 470 chipset or equivalent.
my present mobo has one m.2
Id be willing to get multiple evo’s if they were more than two nvme in the array. just to save on budget. I can always add another in time, so should I plan on a 4 way raid 0 regardless? and just start with the two?
More importantly, how well does linux interact with intel vs amd with raid 0 and the OS being installed directly to that partition?
Can I add multiple arrays, say two for OS and another two for storage? and have four total? two partitions on one array or two separate arrays? cheers for any tips or links you may provide so I can better refine my research.
