Rage id / amd... five years later :D
This has been in my steam library for donkeys
Haven't been able to play it properly since i went AMD... until now :D
Still doesn't work 'Out of the box' but can be made to work on newer gcn with a little tinkering.
Had to monkey around with settings
  • rage config file
  • startup options
  • deleting bik video files
but there you go, buttery smooth 60fps at 1080p with no noticeable texture pop...
ABOUT F**KING TIME!
Rather bizarrely having a better time with the discontinued / unsupported 64bit version as it seems more immune to memory leak bugs (probably still going on, just not as noticeable on a machine with 32gb :D e.g no crashes to desktop)
CPU transcode score of 155 mega texels
I only really did this for giggles.. spent more time getting it to run properly than actually playing it.
don't ask me why.. i just seem to get enjoyment from making broken things work
edit - will post settings when i get home if anyone is interested.
Cool if you should post up to PCGamingWiki help others out I'd they have IR had the same issue.
